Receiver Alignment Hookup
2FB327
270
54
After reading the repair manual and the owners manual for my signal generator, I need some help. As stated above in the Cobra repair manual, my questions are:
1. Where do you hook up the VTVM? Is there a way to do this with a DVM?
2. If someone could explain how you do it, it would be so helpful.
Thanks
At the AF output. Your DVM should accomplish the same thing, but may load the AF down.
BTW, I've read and tried using a scope to separate the signal from the noise and prefer that method.
Thanks your the man, could you recommend something that's available, and your saying it plugs in the external speaker jack.
a dvm does not work. you need a meter with a needle on it to peak with. you hook it to the speaker section .
You're exactly right, I keep an analog meter here for peaking (or dipping) circuits, but I tend to grab a scope probe for that stuff.
Would you be so kind as to explain how you use the scope to accomplish this.
As others said a scope or VTVM for this operation.
If you do not have either you can run down to your local RS or walmart or Lowes and pick up a cheap analog meter. 10 to 15 bucks. Then google RF-probe and build you one.
Now some will tell you a DVM will work but the responce is a bit slow and cause you to over shoot you measurment.
Unless you are a very, very patient person.
Most are not lol
The RF-probe incase some need
Heathkit Model 309-C RF Probe -- Schematic diagram
http://www.nostalgickitscentral.com/...chema_309c.pdf
Heathkit Model 309-C RF Probe -- Assembly Instructions
http://tubularelectronics.com/Heath_...RF%20probe.pdf
Here is the Heathkit V-7a VTVM brochure / write-up.
http://www.w6ze.org/Heathkit/Heathkit_019_V7a.pdf
DIY BUILD your own RF Probe !!
RF Probe from a Sharpie by KC0WOX
http://golddredgervideo.com/kc0wox/rfprobe.htm
Classic RF Probe by N5ESE
http://n5ese.com/rfprobe1.htm
Ballpoint RF Probe by N5ESE
http://www.n5ese.com/rfprobe2.htm
How KI6DS Built the N5ESE RF Probe - NorCal QRP Club
http://www.norcalqrp.org/KI6DSrfprobe.htm
Diode Selection for RF Probes - Clifton Labs
http://www.cliftonlaboratories.com/d..._rf_probes.htm
Hendricks Kits - RF Probe
http://www.qrpkits.com/rfprobe.html
He won't need an RF probe for AF, but those are some cool DIY links if an RF probe is needed (y)
Radio Tech, I have seen the probes, are you saying that you hook the rf probe to the scope and then probe the radio?
If so at the speaker jack?
I probably have the things to build a probe, or go to the store and get an analog meter, but I'm more interested in how to hook up the scope to do it.
I didn't realize you had a scope, just plug your probe in and clip it to a speaker wire. Watch the signal as you peak the circuit.
Reactions: 2FB327
Oh, so you have a scope. Some folks would probe the speaker output. Connect you SG to the ant in and set the output to a minimum level. Adjust your scope so you have a few division displayed. The problem here is signal to noise. I always scope the output of the circuit I am tuning then move to the next. Like in your diagram above I go to the output of L2, adjust then move to L3, ect.
I am basicly deaf in my right ear and only have 60% hearing in my left. So I trust my scope to adjust the signal rather than noise.
Reactions: 2FB327
Thank you very much, now I have two ways.
I'll pick up an analog meter next time I'm out.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
