Need help choosing antenna for car
Kind of car and if you plan on hard mounting or mag mount would help. The sirio line of antennas work well and have held up to some good bangs on the branches with my work truck being 8ft + at the top. There are so many different antennas on the market that you almost have to do a bit of research to see what you like or what is best suited for your needs. Hope this helps and have a great one. God bless.
Reactions: midnight special
Sirio Antenna is the next best thing to the 102 inch whip and looks good as well.
Sirio 5000
Sirio 4000
Mag Mount Options Available
Hard Mount Options
5/8 Hole Required
HP-AC/U Angular Connector with 5 meter of RG 58 Coax
SG-AC/U SO-239 With 4 Meter of RG 58 Coax
DNJ Radio Sells All of The Above
Reactions: 357magnum
