Quality Sound
It's usually a ham rig running a studio style mic from Sweetwater Sound into a mixer and rack gear that cost even more money. And they do all this to talk on 11m. Even better yet usually 3 out of 10 actually sound good, the rest have a nasel monotone drone sound.
Reactions: Big Daddy
Only if they neglected to widen up the response in the radio by modding the audio circuit . . .
You know you got a big radio when you squish folks with the sound of nothing. You don't do that with 2W swinging 16.
Bob Heil uses a £120 Alesis Mixer in his shack. In the following video he mentions using a $50 Behringer mixer.
Start watching from about 44 minutes. Lasts about 20 minutes.
Really rich sounding audio does not require a lot of money and a rack full of gear. It just requires some knowledge and a little bit of "techpertise". People that spend thousands and load up an equipment rack lack both. It is amazing what can be done with the proper microphone, a little bit of EQ, and a small amount of compression. Modern ham rigs contain both an EQ and a compressor however most people have no idea how to set them up for nice audio and simply strive to be loud or punchy.
The video I posted shows what you should be aiming for. I think its about 50 minutes in or thereabouts.
Get a simple non modified 148.Buy a mic compressor eq. You'll need a scope and a way to sample your over the air audio in real time
Under $500 and you can begin hifi. Most radio operators are clueless on what makes AM sound good. Start cheap and get your learn on.
Reactions: 543_Dallas
Good info I have some studio mics and some good mixers here to try some of things Bob talks about Thanks for sharing that with me.
Experiment and have fun that is what it's all about. I need to work on my receive audio. Some would say I talk more than I listen. LOL That is one thing no body seems to do Nice speaker set-up to make to make incoming audio sound great.shack1.JPG shack2.JPG
Ha! Thanks for reply. Did you come out of the line out or the master out, is voltage the same or one higher than the other? And you are correct experimenting is also one of the high lights of operating.
