Can speaker wire be used as an antenna and if so what is min gauge for legal power( or 2kw ) or higher to be safe/ upto 5kw or so like some of these baluns and line isolator seem to be made to handle it?
Wire is wire. It doesn't know if it is being used for speakers or antenna or to dry laundry. Copper wire is preferred for reasons of conductivity, solder-ability, and price/availability. Even very thin wire will handle substantial power so size is only a factor where strength is concerned. Usually 14 gauge is used as it is a good trade off for size and strength. You will never run enough power to melt 14 gauge wire.Stranded is best as it is flexible but copper-weld is often used where long runs are required. It is copper plated steel and is usually solid.
Read Capt KW's reply - the first couple of sentences, anyway. The larger the diameter, the greater the bandwidth, BUT you're not going to notice any significant change in bandwidth at HF.Ok, what about 10ga electrical wire as well as monster cable @8ga? Also does gauge make a difference when using formulas aka 468/freq? And also on bandwidth?
Also what determines power handling capabilities be it wire solid or stranded or aluminum poles or copper poles ect? And can you mix copper and aluminum as well?
I was wondering cause 6m, 10m, (11m), 12m, 15m, 17m, 20m, even to 30m as heavy as 8ga is. It is possible to over come that weight and have terrific bandwidth but would have to use a support mechnism but, anything lower the legnth would really tax it weight wise, but I am speaking I speaking in general terms of worth it too or can 10ga do as well too and weight would be really really a lot less on 10ga vs 8ga.
