Say, Marconi, I think Bob's being serious.
I did actually turn my Vector upside down. Remember?
It became a NTO - New Top One Dimensions for Homer
When Spring comes I am going to return to this NTO and work on it with my analyzer back home from repairs/calibration. Also, I may build me another Astroplane. If we get new exact dimensions it would be helpful.
I wish I could get to the information where we put the analyzer on the AP as I moved the spreader up and down the center conductor. It's on a locked up hard disk drive.
That coil is HUGE!Homer,
all i can find is this ,
http://i5.photobucket.com/albums/y152/ukmudduck/antenna/P1000434.jpg
& this
http://i5.photobucket.com/albums/y152/ukmudduck/sirio 827/P1010232.jpg
or the 1" fiberglass rod from my i-10k.
I linked the thread about the NTO I built in the post with the picture of my V4 to NTO photo.Homer . . .
I must have missed your report that you had a NTO, . . . or are you speaking for Bob? If you did build a NTO from your Vector...did you also report that is was not an AstroPlane?
i must have got interrupted and sat on the keyboard eddie,
try again,
i have no doubt the top-one will work as well as other antennas when mounted at the same tip height,
it has a 4ft height advantage of current maxima over most antennas like the astroplane has,
at this location that should be an advantage over a 5/8wave imho
thanks eddie,
i think you would need everything else apart from the new radial configuration equal to see if there is any change like they claim,
i thought of a potential better way to modify this and other antennas eddie, the idea came from the top-one i made,
a vector with its cone turned upside down is the same thing,
http://i5.photobucket.com/albums/y152/ukmudduck/topsyturvey.png
convert a vector into 2 x 1/2wave
try again,
Eddie.
its about converting a vector to a 2 x 1/2wave by inverting the cone like the new top-one and using a phasing stub/coil 1/4wave up from the feed-point,
there won't be much separation between the 1/2waves so you can't expect 3db gain but it could be better than the stock vector on the same mast.
You may be correct about it being it not special after the isolation of coax and mast. However, I believe the antenna will be all it was designed to be when the mast is isolated the exact distance down from the loop as the twin top bracket is above the loop and the coax is choked at that same point. This is the stated design parameters of Orion/Avanti in the patent submitted in 1968 and published in 1971 that I linked above.Thanks Homer, I checked that old thread out and found it interesting...we are talking today about much the same things. Sorry, but I did not remember that thread. I remember introducing the idea about the NTO, but little else. You know what was missing was the TVI issues I recently brought up. I remember this much however, I did not want to be telling guys the high regard I had for the NTO, and at the same time warn of the CMC problems I was having. I've worked my A/P antennas for some time and like you said earlier I never noticed this issue before.
IMO, this antenna is not only a simple 1/2 wave radiator...I liken to one big tuning device that radiates well from the antenna, but it can also radiate well from the supporting mast...and that might not be so good. On the other hand if Bob's idea eliminates this issue...then it may only respond like other 1/2 waves and be nothing special.
I can't wait for Bob's report.
