Eddie,
What is it about Henry's article that makes you think it does not address the question of what the CST animation is displaying?,
To my eyes the animation displays the near magnetic H-field in
A/ m and direction around the conductors,
If it was the usual method of measuring field strength from antennas it would display the electric E-field in V/m,
the stuff that makes your heathkit needle move,
I can't think of a better way to explain its the near magnetic H-field than Henry's FEKO images show us,
For sure it would be easier to visualise if FEKO used the same colors as CST but included the arrows for direction as well,
If anybody has an alternative explanation that can be proven by links to respected sources id like to see them, Im always looking to learn,
Homer
i have argued for years the astroplane should be tested as the patent intended it to be used at the same tip height,
your other antennas?
did they all have an efficient low loss matching system ?
all made out of the same tube with the same resistive losses ?
were they all decoupled from any conductive mast & the coax choked & have radials for return currents?
did you test them with an un-modulated carrier in stable conditions with people out in the distance and without other antennas close bye?
i have seen good and bad results from end fed antennas such as a99 and imax, they are not as bad as some people make out,
no worse than other cheap endfed halfwaves such as a silver rod copy,
i can't think of a well constructed end-fed halfwave on the market to compare to other antennas,
When you don't decouple them and give the return currents a path that won't potentially spoil the pattern you are playing a game of luck with mast and feed-line currents as W8JI tells us,
lots of people run ground wires to their mast/antenna without any thought about common mode,
very few people think about the electrical length of their mast and its common mode impedance even though they may have used a choke at the feed-point,
They may DC isolate the antenna from the mast by wrapping the mast in insulating tape or similar, its still capacitively coupled,
how many people believe a j-pole connected to a conductive mast is a good idea?
lots of ham projects suggest they should be, a few articles even suggest its needs to be for the antenna to perform correctly,
These things can lead people to the conclusion that some antennas are junk, don't perform well, cause tvi, lip burning rfi, speech processors not working, distorted audio, noisy rx, touch lamps turning off and on, the list goes on,
Its why some people say they work ok and some people hate them with a passion,
Its not so much the antenna as how its installed,
My fork handle choke and radial solution is capable of turning what seems like junk into something perfectly useable even if it made some people laugh
