linear cookbook
cbkidd1
Well-Known Member
May 3, 2005
847
156
53
64
pa.
Hi, Would anyone still have a copy of the Linear Cookbook.exe They could send to me. I lost mine when my hard drive went down. The copy's i came a crossed on the net have the paper work missing. t/y
Thank you booty, That is were i got what i have now. But what is posted there dose not have the step by step directions on putting it together. I need them because the amp i bought looks just like the 4 pill in the linear cookbook. The amp has no transmit output. The radio puts power straight through with amp off or on. I have low swr's with the amp off with amp on they are 2.4 I checked the transistors voltage with the amp on the collector had 13.53 volts witch is the same as the output power of the power supply. At the base i got 00 volts dc. I think the relay is not wired right. I am no teck but i think there is no power getting to the input of the amp.
LOL, I can remember buying some of the discs direct from PSF technologies about 10 years ago. Somewhere I have the full collection. Even bought a biasing board. Too bad he didn't copyright the stuff. He sold complete kits with all the parts. All you had to do was assemble. Too bad designs are flawed. They need a few modifications to get right or get the efficiency up. And nope they don't explain the LC circuit for some of it so need to make coil as exact as possible to get it close. Like on 6 and 16pill. The 8 pill pulls really hard for a class C box.
