The .64 Wavelength Vertical Radiator
Hmmmm.... the 5/8 wave vertical had only a 2.86 dBi max gain at a TOA of 32 degrees, something to a .64
hey ,uuh,CTStallion,, the CLR 5/8 ~ has over a 12db effective gain, so i call bull! 2RB said that.
Welcome to the forum 2RB.
Hy-Gain has posted here, http://www.cbtricks.com/ant_manuals/hygain/model_473/ad/index.htm, several different values from 4.0 - 4.75 db gain on their CLR2 over the years, but 12 db gain is a bit high IMO.
Can you post a reference for such gain as you note above?
Could someone do one for the sirio tornado with a #2awg solid copper wire from base to ground. Feedpoint height is 27ft. If possible. Live In Daytona Bch, FL, area, flat land and am about 2-3 miles from beach. Thanks for any replies or help. Just curious. Don't have my Anritsu anymore or I would see for myself. Again thanks for any replies and/or models.
222DBFL, the Tornado is a classic 5/8, yours should perform like the classic 5/8 he did 3rd from the top.
After reading and comparing his graphs, I'm actually quite impressed with the .64, especially now that I see it has the highest raw gain of all, 3.37dBi @ 28°.
It's 3.37dBi @ 28° upper lobe beats both the 5/8 2.86dBi @ 32°, and the Vector4K/Sigma4 2.75dBi @ 27° while still maintaining a hair MORE gain (.07dBi) than the 5/8 at the low angle of 10°.
...and with only about a third of a dB less than the Vector4K/Sigma4 at 10°.
So much for all that hoopla about there being no difference between a .625 (5/8) and a .64.
...and that no one ever marketed a ".64" - R/S .64, Taylor GLR4, Imax, etc.
Yet there's more gain advantage over a 5/8 by the .64, 3.37 - 2.86 = .51dBi,
(AND at a slightly lower angle of 32° for the 5/8 vs 28° for the .64)
than there is by the Sigma4/Vector4K over a 5/8 (2.79 - 2.35 = .44dBi) - and that's insignificant?
The Sigma/Tagra/Vector/Larry's beats the 5/8 by .44dBi and everyone goes apesh!t & does backflips over it,
but puts down the .64 as an "insignificant difference" compared to a 5/8 even with a .51dBi improvement...???
HUH??
And I'll have to add, to be honest I don't really believe the Imax IS a .64.
- Remove 12" for the bottom mounting plate from the 24' antenna, then another 5" or so for the matching network and you have left exactly 22.6',
or a true .625 (5/8) at 27.185MHz, center of the US CB band.
Ah oh, I fear that may have been .03¢ worth![]()
therefore all antennas were modeled at 20' above REAL GROUND (at the feedpoints),
First off, thx for all the replies from both NB and The DB. Heavy Metal, If you are after good local and long distance dx, that is a good height. Also why the fiberglass rod at the antenna? To isolate it? Just curious. Also add a dipole to your antenna array if you don't have one. Give one a try, they work well and are easy to work with if you have trees in your yard. Get it to 18ft which isn't much and it will reward you at times when the Imax won't. JMHO.
