KC1ACI Repeater
W1MSG
Now W1MSG
May 9, 2010
499
18
28
MA
The KC1ACI Repeater is now in operation. Located in Central Massachusetts. I have done some link testing with the W9WDX Repeater and we are in business. D Star of course.
Lets get this party started !!
Awesome! This is all running off a Raspberry PI, correct?
I have the XRFWDX XReflector working - I just need to get it to it's final resting home for use. I also want to get a dashboard in place for it, but I can do that over time.
I was also thinking about starting a Starnet group that we can subscribe to when we're by the D-Star radios. Any interest?
Yes its all on the Raspberry pi. I just started the Trial period with the coordinated pair of frequencies. Not sure how long it stays in a Trial period before it becomes permanent and gets published in the repeater lists, but there shouldn't be any issues.
I would be up for a Starnet Group!
Old Thread but the KC1ACI B Repeater is still in operation. I am running a Kenwood 820 Repeater with a DVRPTR v1 Board and a new Radxa Quad Core linux box. You can check out the dashboard at http://kc1aci.no-ip.org ..
Craig
Craig, I saw from the dashboard tonight that you connected to both the W9WDX repeater and the XRFWDX reflector today. I wasn't around the radio as I had the Jeep gas tank out, replacing the fuel pump :(.
What times of the day are you normally monitoring your repeater?
I'm usually listening in the afternoons. I just did my fuel pump not too long ago. I was replacing the tank skid plate and broke the plastic nipple off the fuel pump module .. Not a lot of fun.
I'll connect in later today ...
The KC1ACI Repeater is no more. It wasnt getting used and I just dont spend enough time on DStar to justify. Its new home will be in Colorado !
And the KC1ACI Repeater is back alive. Picked up a couple of MaxTrac radios and a DVRPTR V1 board and we are back in business. Check out the repeater dashboard at http://kc1aci.ddns.net
Its not 100% just yet waiting on a new Duplexer which should be in very soon.
Yes we should, everything is up and running now. I also put together a Pi with the DVMega for mobile use...
