Ranger RCI 2970N2 for trade
camaro1
Well-Known Member
Nov 2, 2012
1,077
467
93
wisconsin
RCI 2970n2 ,, I got this along with some other items from a local guy, it has a bad main cpu,, that is what his guy told him and as far as I can tell his diagnosis is correct, radio is clean and everything inside looks good, no hack mods or anything out of the ordinary inside. comes with all the original items in the original box
it turns on, no display or functions, can hear some faint static from the speaker and the amp board does key up with the mic,, that's about all I know, I had the covers off and just looked at the basics and made sure there was power and ground at the cpu board. again everything inside is as it should be.. and it does have the 11m expansion module in it.
I figure someone could swap out the cpu board from a 2950dx( I think they are the same) and have a good 2970n2,,, or you could take the amp board and lower cover off and put it on another radio,, the amp looks like it would be very simple to make work on other radios.
make me an offer or items to trade,, meters, mics, tuners,
Someone got a good deal. The amp board is worth that alone! Glad to see you got it sold Camaro1. Good deal for both ends!!
Reactions: camaro1
    63Sprint has left the room.
