2 Dup/diplexers for 2m repeater?
MrClean
New Member
Mar 11, 2016
29
2
3
PA
Has anyone used 2 to get there desired split? And if so where how would you hook them together and what do you put on the open connectors?
If I can use 2 of the $100 China ones and good connection coax I was thinking this may work to get a 600khz split (or 1mhz if easier.) I am still open to 2 antennas and radios spread 65' apart if need be.
I plan on a simple 10w repeater using 2 Motorola GM300's and Idom IV.
you do not want a DI-plexer, they are for cross band operations, for same band splits, you need a DU-plexer,
yeah, certain manufacturers (particularly COMET) use the incorrect terms too.
any well made COMMERCIAL cavity will do what you need, most AMATEUR cavities are, quite frankly POS's, that use Nickel and/or chrome plated connectors.
YMMV
YMMV
To clarify my question better, has anyone on here used 2 of the 4-6 cavity mobile duplexers to get band split desired and how do you link the unused connections for the unused part of the split?
I don't mind running 2 antennas and just running a VERY low loss coax to the further one (I got some 1/2" Heliax laying here)..
Or do/can you dummy load the unused portion?
