#56 B&K 2040 Signal generator PLL issue
Bummer that the schematic wasn't correct.
But you still nailed it just the same.
Cool stuff!
Wass the voltage feed stable to the ICs?
Thanks.
Yes voltage was pretty solid.
I had to cut one part out due to noise from a piece of test gear I could not hear. But the camera sure did. That was the alignment part. Which was why the unit was splattering 5 channels wide.
    boog351 has left the room.
