CRUSADER BASE AMP..125 NEEDS HELP
SW1
New Member
Sep 22, 2016
4
58
Hi everyone,
Picked up a crusader 125 amp on a song fires up recive amp works key it up and nada antenna warning light comes on too...lokks like a cold solder joint on the antenna jack...anyone know anything about these amps???or anyone that can fix it in the Utah area...
thanks in advance SW1
No worries. There are just so many amp names with the same insides that it's easier for a lot of techs to look at the inside of the amp to see things and also to look for issues. Be very careful taking the lid off and DONT PUT YOUR HANDS IN IT!! It will kill you if it's a plug in the wall type it could be holding some major voltage at the moment. Ready yo strike like a snake and then it's either you wake up having shizz yourself or you don't!!!! Neither cases are good!!!! Be safe!!! And have a good one. Someone may be able to answer your question sooner by the name of the amp as you have it posted. But pics do go a long way!! Again, good day.
Courtesy of cbtricks.com:
Also, see here for more.
Too bad no shots of the board on CBtricks.com, I found a video of one on youtube but not much else online.
-Leap
Reactions: 222DBFL
    357 has joined the room.
  • @ 357:
    HEY SKIPLAND IS ROCKING ON 38 RIGHT NOW. 9PM PST JUNE 30
