Help with XFORCE XM400 adding SSB delay
Adamf
243
30
71
Hi all, I have an XFORCE XM400 amplifier that does not have the SSB delay so I plan to add a 1000uf capacitor and switch so it will but I am not 100% sure where to connect the capacitor to the relay, can someone look at the picture attached of the relay in my amp and tell me which post is positive and which is negative (ground) so I can connect the capacitor to it? I have e-mailed and texted XFORCE but can not seem to get an answer. Thanks for any help. Adam
All you have to do is take the + side of the 1000uf cap and put it to the pole on the relay where the keying transistor solders to, and wire a switch from the - side of the capacitor to ground. That should get you some delay. If the delay is too short, increase the capacitance, if it's too long, decrease capacitance. Hope this helps. :)
~Cheers~
~Cheers~[/QUO
Hi, thanks very much for the post. I understand all that but was hoping that someone could tell me which lead on the relay in the picture is the positive post. Thanks, Adam
Hi, thanks for the post. I understand all that but was hoping someone could tell me which lead is the positive post according to the picture I posted of the relay. Thanks, Adam
Exitthirteen pretty much gave you the game. Other than that, you take a chance if you have no idea of what you are doing. Best to get with a local if they know what they are doing. If no one is around; then send it back to XForce.
Reactions: 222DBFL
The positive post of the relay is the left bottom post in the picture you provided, the post that has the transistor and small capacitor soldered to it.
~Cheers~
ExitThirteen, I can not thank you enough, you are a good and kind human being! Thank you very much! Adam
I am actually out of town till next weekend but will do it then and advise, you have gone above and beyond!! Adam
Hi Exit Thirteen and all who are reading this, thanks to ExitThirteens GREAT help I did the delay mod and it is PERFECT. Xforce finally did answer me and was very nice and sent me a diagram but of course I already had ExitThirteens help so I was all set. Thanks again! Adam
