I appreciate all the comments. Everyone is very kind. Thanks. I'll get to bonding and such lol. I'll let the cat out of the bag a little. Radio is a FT-857d
I run FT450D w/dx500.....hf rig is only way to go.I appreciate all the comments. Everyone is very kind. Thanks. I'll get to bonding and such lol. I'll let the cat out of the bag a little. Radio is a FT-857d![]()
I wonder why it makes a difference with my radio if the mounting bracket is touching a metal surface or plastic. When it touches a metal surface the radio doesn't act right.
I've done this. It come in through antenna. However, reading about the mentioned ground loop effect may be causing it. Worth a try. I'll move my ground to the chassis tomorrow and see what happensheres an old trick to try. have your radio on with car on..
unscrew ya coax is the noise still present? if so its coming thru ya
power wires . if radio goes silent then its ya antenna picking it up.
After reading the link you've shared this actually makes perfect sense. I've always ran directly to battery. I had a jeep with electrical problems every time I keyed the mic. Windshield wipers going off when transmitting etc... now that I think about it, my 2004 GMC truck is drive by wire throttle body and when I key up with power it cuts the engine like I'm flooring the gas and letting off. Haha. Looks like I'll be moving my ground first.You mention wiring to the battery. Are you wiring the ground/negative wire to the battery as well? This is a no-no, not good practice especially on modern cars with smart charging. Instead you should run the negative power wire to a point on the body/chassis adjacent to where the main negative wire from the battery connects to the body/chassis.
http://k0bg.com/wiring.html#power
It could be that by not doing that and going straight to the battery you're creating a ground loop when you touch the bracket onto the metal bodywork of the vehicle.
I have one, I also use a QD in between the base and the AT. I use a 3 magnet MFJ mount on the top of my pickup cab. SWRs are pretty good although I can maybe tweak them a little more (I had to cut about an inch off the top). ]
M0GVZ, thanks for the reply. I plan on doing the bonding/grounding. Trying to figure if I should go with braided straps, or just use some wiring.
