Yes but we all know the real reason its there...amps.
I've had better luck on ch. 4, if no-one is bleeding that far.But what about the CB operators who love QRPGotta be 1 or 2 on channel 6 right?
Really?I've had better luck on ch. 4, if no-one is bleeding that far.![]()
If you look at the graph of solar cycles, you will notice that they aren't simply either up or down. You will find short term peaks in between. When these happen - and they will for a short time - you will find out...for?
lol
If you mean wait for the next solar cycle, then I agree.
Last cycle, there was some joker on the East Coast on ch 6 that bled all the way through 40 ch. I was hearing nearly as well on 38 LSB as I could on ch 6. That is just plain nasty, and nothing to be proud of. Hope he learned to do better than that; that is - without bleeding over and making himself a prime FCC target. Otherwise, I'll turn him in - lol.
You could have picked that guy up with a radio that used a K40 - lol.It's all about your antenna Robb!![]()
This how I used to feel about the tip120 mod, unitll I tried it on a TRC-427 with a 1uF 450v cap. What I got was clean output at any deadkey, the AMC adjustment was never touched from factory alignment. Set at 90% for full power output, and as you lower the carrier the waveform never goes to hell, also you harldy see the needle kick to the right on a AVG reading meter even at 0.5 -1 watt carrier, sure the radio won't have "super-modulation", but it will provide crisp clear audio. Behind a good linear, you would see honest peak #'s, and likely no BIRD SWANG.like I had said it is a usless add on since like the cobra 29 radios it will swing the same amount of out put from 2 watts as it does with a 4 watt dead key.
Isn't that what it is all about? Communication not band devastation!This how I used to feel about the tip120 mod, unitll I tried it on a TRC-427 with a 1uF 450v cap. What I got was clean output at any deadkey, the AMC adjustment was never touched from factory alignment. Set at 90% for full power output, and as you lower the carrier the waveform never goes to hell, also you harldy see the needle kick to the right on a AVG reading meter even at 0.5 -1 watt carrier, sure the radio won't have "super-modulation", but it will provide crisp clear audio..
Yes my friend; that is exactly what I'm trying to promote!Isn't that what it is all about? Communication not band devastation!
