Ok so according to Lester's own meters and video we have a KL Stinger in radio doing 30 watts rms swinging to a peak of over 150 watts!!! At most it should be swinging to 120 watts if we observe the 4:1 rule!
On top of that we have an audio compression SP1-a device that is going to increase the average audio level and thus the duty cycle that the amp see's when they are both on.
Can you say recipe for short life span????? If that was setup to key 20 and swing to 60 assuming it never say a high swr it would last forever. If was set up to maybe max out with a 25 watt key swinging to 100 it would last a lot longer.
If it was set up with a nice variable rf power tuned for a max of 25 carrier swinging to 100 and the owner ran the rf power at the 12 O'Clock setting again it would last forever.
I understand the amp has an on off switch but who wants to have a system where it is all or nothing?Imagine operating your car that way either off or at WOT.....LOL
He obviously know's this amp should not be outputting this much power he even says as much in his own video so why would anyone let it leave their shop like this?
I am sure we will hear this radio splatering all over the place at some point. Too bad radio's did not broadcast an " I am a splatter box" coded signal on one of the many sub carriers they generate to let everyone know! LOL Even better if they identified the name of the tech that worked on them!
