I finally got to the astroplane, made a fiberglass isolator last night & started assembling it today,
I'm not sure, but I think Homer might have isolated his A/P too. Where are you going to put the isolator?
I'm wondering what result you'd get if you were to mount it on a non-metallic support, with appropriate coax choke(s) and a 1/4 wave above any metal tower/mast/guy lines?I did isolate the AP sometimes. 1/4 wave below the ring. Put a choke in the coax at that point always. Not sure whether I noticed any difference with isolation or not.
#1 in the list. The overall length of each crossed radial will be 48"
I thought I'd try a 20' fir 2"x 4" with bolts in place of the U-bolts for mounting, and either pull the coax out @ 90° or wrap an appropriate current or voltage choke every 4' - 6' going down the 2"x 4". Maybe both.If you used a none metal pole the coax would do what the metal pole does but spacing would need tweaking to get back to 50ohm.
That was my understanding, too. Using a nonconducting mast after ~1/4^ below the ring may yield good results, but all the way to the top bracket would be remiss. My metal mast sometimes never reached the earth, but always was at least 9' or longer below the ring.The mast IS part of the antenna as its typically used homer,
for impedance to be near 50ohm with the spacing used the mast should be close to 1-1/2" diameter,
the patent tells us the coax will do the same job,
i can't think of any other cb vertical that won't work correctly if you use a none conductive mast & bring the feedline out at 90 degrees,
or one that changing mast diameter directly effects feedpoint impedance,
I don't know what you mean by wind a current or voltage choke NB,
you said something similar about the gainmaster choke,
i only know of one kind of coax choke, current chokes,
Wait, so you're saying Sirio wasted a lot of money wrapping 16T of coax when all they needed was to enlarge the plastic from 3" to 4.25" and wrap 5T x 4.25"?The gainmaster choke is a current choke NB,
several people have built homebrew versions using 5 turn chokes of rg213,
the choke creates the high impedance voltage node the correct electrical length from the feedpoint,
i predict choking the astroplane up around the ring will spoil the pattern,
imho for best results mount the astroplane on 1/2wave x 1-1/2" mast isolated from the support structure & isolate the feedline at the same point to minimise currents below the hoop.
