Receive audio quality issue..
67Malibu
Apr 23, 2010
9
I have two Washington and 1 Lafayette SSB-100 CB base stations exhibiting the same problem....receive audio sounds restricted, almost like the speaker is old and dried up. Transmit audio is unaffected. Symptom persists even when using known quality external speakers. Re-alignment had no affect on this condition. Suspect component failure, but I am unsure where to focus troubleshooting efforts. Any help greatly appreciated.
Using the all original capacitors in the units tested?
Electrolytics can dry up over time and exhibit high ESR, this can cause issues.
