Dentron Clipperton L
BlowinSmoke
121
50
71
Can anyone tell me what a nice Dentron Clipperton L converted solely for 10/11 meters is worth. It can dead key about 1400-1500 watts output. Thanks.
If he is "dead keying" it at that output, it will need new tubes, as well as the tank circuit rebuilt. Will no doubt need to the power supply board replaced to, as well. New tubes are 320.00, new power supply board 100.00, and who knows what he did to the tank circuit.
http://harbachelectronics.com/shop/dentron/pm-clipl-replacement-power-supply-module/
https://www.rfparts.com/tubes/tubes-572b/572bmq-tay.html
If all the componets to the tank circuit are there and can be put back to use, maybe 250, if not , then CB junk
Rich
Thanks for the reply. Maybe I should have said that the 1400-1500 watts output is un-modulated. So I guess that would be the modulated peak power. That seems about right for 4 of those tubes in a single band amp. I don't think the PS or tank circuit should be a problem. It's got to be worth more than $250. Just the amp alone sells for $500 or more.
Thanks, I assume that the market would be for 27 mhz users. That said, I would think a 1500 watt amp for 27mhz is worth more than $500.
It's worth about $450-550 with good tubes in it's original Amateur built condition...IMHO the way it is now...I would pay maybe $150 as a parts amp. You can buy SB-220 Heathkit's nowadays with good tubes and not butchered up at Hamfests for $500.
So I guess to some that Clipperton...it's worth more but nobody sane.
All the Best
Gary
http://www.w2xc.com/Clipperton_Notes.htm
Drive power: 65-150 W for full output
Maximum output power: SSB: 2 KW (PEP input)
CW: 1 KW (input)
Dimensions (W*H*D): 370*170*400 mm
Weight: 34 Kg
Manufactured: USA, 197x-198x (Discontinued)
Other: Power device: 4 x 572B
New price 1979 in the US: $599.50
The Clipperton, SB-220, SB-200 are no damn good on 10 meters anyhow. None of them make good power and easy tune up on 10/11 meters. That's why a dedicated amp for this band is more desirable and hence should have an appeal in price over it's stock performance on 10/11 meters.
Where did you get that info...interesting...
Sounds like you've made up your mind that this is a Superior Amplifier!
Buy it and GL
All the Best
Gary
That's just it....it isn't a true 1500 watt amp. Those 572B's are getting beat to death making 12-1300 watts output on SSB . The limiting factor is not the tank circuit but the tubes. Running them in AM service is even harder on them than running SSB.
Reactions: tecnicoloco
Since it's for AM, you need to get something bigger. Say something good for 2000pep. Then run it lower for longer life so it isn't ran full bore. Components are not getting any cheaper.
Reactions: Knoxduder
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
