Imax 2000 EXPOSED!
DXman
Yes, that's 3100 degrees F. Nine yrs of hard work.
Apr 5, 2005
1,782
1,383
173
79
West Coast - Washington
Just came across this site, interesting for sure.
www.qsl.net/kg6aoh/imax2000/
Hope the link works.
DXman
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=dxman@worldwidecbradioclub>DXman</A> at: 12/4/03 4:05 pm
Mine became <span style="color:maroon;font-size:large;">Well Exposed</span> when lightning hit it.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/sick.gif ALT=":x"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":(">
73, Mike KD5VHF@hotmail.com</p>
I never understood where he got the idea the 270.5" wire Imax 2000 was a .64, bad math? It's a perfect 5/8.
Beginning with the speed of light in millions of inches per second:
11803 ÷ 27.185 = 434.2" x .625 = 271.35" x .9979 (VF) = 270.8 - Circumference of .1 x pi = 270.8 - .3 = 270.5" for a 5/8 NOT .a .64 at 27.185MHz - center of band.
Now viewable here: https://www.scribd.com/document/10938803/The-imax-2000-exposed
Reactions: Heavy Metal
Hello NB: I suspect that the Fiber Glass Radom decreases the velocity more than considered. Making it shorter in length.
The 102 inch stainless steel whip when replaced with a 96 inch fiberglass whip antenna has a close to the same VSWR. Or the manufacture is some how limited to it Radom parts limiting its length, and the tuning/matching network is designed to match the antenna. Good question tho.
.64 on 10 meters maybe?? Just drinking first cup of morning coffee and throwing my 2 cents but I think I read somewhere it was .64 on 28 MHz
That makes good sense, but it's more like a .65 at 28.4.
Jay, I'm under the impression that the FG radome doesn't do much at all, but it would need to be a VF of about 97.4% for that to be spot-on.
Good to hear from you, Jay. Are you still making the I-10K?
Hello Jay,
Any chance you may be manufacturing the Interceptor 10K antenna again in the near future ?
Hello NB: Ok yeah these threads get put on the back burner and I don't get see them at times, as they go inactive.
Yes there are plans to bring the I-10K Interceptor back into production, and other antennas in the works. A new building is being constructed to hold all the machinery and materials. Local government red tape and nit noid rules from So Cal Edison have delayed the workings.
Those BASTAGES! o_O
Do you plan to keep the same configuration or turn the match 45° to eliminate some alleged .coupling to the radial?
What about the Shockwave - seems to be an almost exact copy?
Good to see you posting out here, 73
Hello NB: I get a kick out of the "alleged" coupling thing. Configuration will be the same.
I sold Chris either one or two Interceptor 10K Antennas, and some parts for Crusader Yagi Beam Antennas, some years ago. Yeah I saw the Shockwave Technology version, ain't that a constancies.
Could you give us a hint of what to look forward to in terms of other antennas to be in your line-up? I presume a yagi or three? Maybe other surprises?
...and I imagine yuor splel chekc kicked in and, like the one in my POS dumb .phone, changed 'coincidence' to "Constancies"?
What's it suppose to be for .64
