So we're do you measure from to tip for that fine line bringing it to 27.185 or 27.000 at .64
Well you really want to make sure that your .64 is a .64 at the
highest frequency you plan to use - since any longer tends to lose the low TOA and sends the RF heading for the space shuttle, in that using a .64 above the tuned .64 frequency makes it effectively longer at those higher frequencies.
I measure from the top of the matching network in the base of the Imax behind the rings & ring threads to the tip, and remember, there's a several inch long capacitor about 134" down from the tip to consider on this oddball antenna which
thinks it's a 1/2 wave.
There is a velocity-factor issue with an antenna made from metal tubing.
A wire will tune at a slightly-longer measured length than than tubing at the same resonant frequency. The thicker the tubing, the shorter it will measure when tuned to resonate at the same frequency as a wire antenna.
The velocity factor used in most 'antenna handbook' calculations says "97%" for HF-band wire antennas. The thicker your radiating element, the smaller that number gets. The famous "234 divided by frequency in MHz" for a quarter-wave antenna includes that 97% VF.
For aluminum tubing in air the velocity factor I've found listed is .9979.
- Often when you have a wire radiator
with insulation, you can tend to get a lower VF due to the insulation material, though the 75M Delta Loop I designed for my neighbor calculated out to a perfect 11803/freq. using standard 12ga THHN with a polyvinyl jacket, so go figure - lol.
He's got a 1.09:1 reading at the target frequency on his Palstar digital meter using a 1:1 balun designs balun just outside the wall behind the radio and a 4:1 at the feed point, after cutting it to 258' and then having to cut 3' from each side to get it under 1.1:1 ending up right at 252' just as the 11803/freq formula shows.
Also, you have to consider the circumference of any tubing as adding electrical length causing a shorter resonant or tuned element length than one might calculate, but I don't believe it's part of the VF, rather more a function of the circumference measurement adding electrical length.
