If the color bands are burnt you can't tell what they were. Need more pictures of the amp.any way to tell what these resisters circled in red were? the bands have burnt off. It is a tx125 amp and I can't seem to find a diagram on google
The front and rear panel, sides, back. More on the circuit board.It works yes. Transmits on all settings but max. Shows about 80 watts. Receive amp light comes on but the receive goes down when on. When you use the max amp setting it seems to oscillate till you turn it off max. Used it once to get a report and it was heard and had improved signal. What more pic can I give?
I'm guessing here, but I think those small resistors are in the receiving boost circuits. Those receive boost circuits don't really help because they amplify noise with along your desired signal. Not selective at all. Get me more pictures of the circuit board so I can look for a trimmer cap in the RF power circuits.It works yes. Transmits on all settings but max. Shows about 80 watts. Receive amp light comes on but the receive goes down when on. When you use the max amp setting it seems to oscillate till you turn it off max. Used it once to get a report and it was heard and had improved signal. What more pic can I give?
I posted a better pic and more info.This one is a real oddball. I have seen circuits in the Motorola handbooks, labeled as "test" circuits that use open coils and capacitors like this for matching impedances.
But every example of a two-transistor push-pull circuit that comes to mind uses broadband ferrite transformers.
This one does not.
Is there a name, or any kind of logo on the front panel. My records don't seem to contain a "TX-125" of any kind.
The two burned resistors reveal no hints about what they do. The one on the right-rear has a first numeral of "1", the brown band that's not burned. Leaves two more color bands to guess.
The one on the left started with the digits "47". The yellow first band is followed by a barely-visible trace of a violet band. But the third one is long gone. Can't see just what it does in the circuit, so could it be a zero point 47 ohm? or a four point seven? or forty seven? Or a 470? No hints from where it's connected that I see to narrow this down.
If the amp works keep it and use it. The receive boost is useless.Well i am trashing it, well it will be used for parts the good ones at least. Thanks every one for the replies and help
