Seen it on a Bird has to be true???![]()
Not really sure why I said all that, must be this Sweet almond oil I put on my face..btw BBI website says"not taking orders" is he just fixing?40 miles away I come over 6 pill ice cream trucks,with only 150 watts. I'm also nearly 100ft in elevation over them,can't put that on a bird meter!
Yeah; but you and I both know is that is the square waves that destroy a transistor faster.Not saying it's true but a perfectly calibrated meter can show these impossible numbers. The more square the waveform gets the higher a bird 43 or any average reading meter will read.
BTW - what kind of power supply did you use to get that voltage and amperage to make 1kw happen?
During a shoot-out, most people won't care how much IMD or harmonic content is present; nor about longevity.. after all the transistors only need to last for something like 10 seconds of WORLDWIDE, WORLDWIDE, WORLDWIDE , or ONE, ONE, ONE, ONE so you can be heard over the other guy (and win).
Can it show you 600w PEP, yeah ("real" watts or not).. But we don't drag race our daily driver cars (we need them to last, not blow up). & that is a "Peak Kit" not a Bird 43P.. (peak reading kits can be tweaked)... 600w seems a little generous @14 volts, but what do I know.![]()
I wouldn't have driven it with 90 watts unless it my own box and I wanted to prove a point, whatever that means, but if he demonstrated the amplifier with a single final radio the results wouldn't be nearly as impressive. Maybe the customer really wants to know what the box can really do?? I don't know, most of Luke's demonstrations are about MAX POWAH90 watts in to a 2 x 2sc2879 type (PP100 originally?) at 14v?
210 AVG/ 600 PEP
8.42 dB gain - I guess that is within scope, ....
~90 watts input? It had to be repaired? Somebody help me out here?
I wouldn't have driven it with 90 watts unless it my own box and I wanted to prove a point, but if he demonstrated the amplifier with a single final radio the results wouldn't be nearly as impressive.
543_Dallas, good call on the meter showing more power after the switch is flipped for peak reading, (it should be the same reading with a dead carrier) and I didn't know that even the slugs can be tweaked! Thank You!
