RCI 2950cd Frequency Mod ?
Carl White
Dec 14, 2017
2
66
Does anybody know how to do the frequency mod on the new RCI 2950cd? I saw the mods on the "normal" 2950, but the cd version looks different and doesn't have the same jumper plugs.
Thanks!
Carl
Thanks!
Carl
It comes with the jumper plug in the mic hardware bag just like the previous version. From what I can tell, the only difference is the new display. I have done the conversion myself on the cd version- piece of cake.
I must have directions of doing an older model which has moving a jumper from 1 set of pins to another set of pins. I went to the mic bag, found the brown jumper. Where does it go? Attached is a pic of behind the faceplate, along with the supplied jumper sitting on the yellow paper. Thanks so much!
I see an empty two-pin socket on the rear of the front-panel display circuit board. How many pins are there on the dongle's plug?
The computer that runs the show is on that board, so, that's where the socket you want should be found, somewhere on the display circuit board.
Reactions: Retro CB Guy
