is there a mod for this transceiver to operate on 11 meters? I've tried to do some research with no luck.
Don't thank me, thank Captain KilowattAwesome!! Thanks!!!
Don't thank me, thank Captain Kilowatt![]()
Did you open it up to hack the chicken band just before this issue?Ok. I've got a new problem with this radio. The led screen isn't working at all. Completely black. No leaking caps or any residue of cap leakage on the led board. What else could be causing this?
NoDid you open it up to hack the chicken band just before this issue?
Battery is good and not leaking.There is the problem with memory batteries behind the front panel of the displays...if left in and not changed or the mod done to remote the battery...it will eat the board traces off the display board when the battery begins to leak.
http://www.aerog.com/ts850_battery.shtml
GL
All the Best
Gary
