My Converted Motorola Spectra
KD8HMO
Aug 3, 2008
172
103
138
Kalida, Ohio
www.protrucker.net
This is my mid 90's Motorola Spectra converted to 2m. This is the 110w trunk mount with the system 9000 control head. I use it as a base station with a Diamond X50 antenna. These radios are built like tanks and can't be beat, especially in a metro area. They are dirt cheap on eBay. Only problem is most will need to be recapped, but not a big deal.
Nice. I run the 45w GM300 as my mobile. I got the USB cable to program it for 8 simplex and 8 local repeaters. My son also has one as a base setup.. Again cheap to use.
First thing you do after connecting the radio to your pc is start the software and download a copy of the radios "code plug" programming file. Then put a copy of it somewhere safe, in case you brick the radio. Then you modify another copy with the software and upload it back into the radio. Basically the same procedure as my VX-7R using a computer.
I'm using the black, L shaped Motorola desk mic with this. I get constant compliments on how it sounds.
Reactions: kaos513
nice rig
I have been looking at this stuff but there is way to many parts and I feel like I am going to mess it up or get non working junk.
