Base Longest Coax Length Possible?
What about when you change bands?
That amp doesn't have a band switch. As I mentioned before you can make reference points for the plate and load settings for quick frequency changes.
I do the same thing with the ameritron amps on my desk. I keep notes of plate and load settings for each band. Operating a multi band amp remotely is possible but not worth the trouble.
I agree with that. I have worked on automated systems and didn't/wouldn't bother with my amp, which I do not use. After I finish my radio room I might use it then.
I would move the antenna closer to your shack as a first choice. The other choice, if you can afford it, is to run hardline, but it is pretty expensive.
Reactions: binrat
