Mobile antenna mount issue
BammBamm
Instigators ...173 on the southside.
May 24, 2010
625
306
93
52
Steger,Illinois
I have a 2017 Ram 1500 quad cab and today I began the process of removing the headliner to install a puck mount, upon disassembly I found there is NO space between the headliner and roof! Even coax will show a crease in headliner. I am now thinking about a triple magnet mount for my predator 10k and running 2 thick ground straps from it to the 2 screws on the 3rd brake light for ground. I am currently using a Wilson 1000 magnet mount...should I just stick with what I have or will I see an improvement? I do have the truck bonded with a total of 16 braided ground straps.
I've never had the headliner off such a new truck but aren't there roof supports that could help conceal the coax? Just an idea.
I had pretty good luck with my old Wilson 1000 mag mount but I noticed an improvement when I mounted my 102 on the trunk lid. I know it's not the same thing but I can only go with my experience. I never tried the triple mag mount so I'm not much help there. Over all I'd prefer a solid mount over mag.
Reactions: rabbiporkchop
The only support goes side to side and the liner is molded to its shape. I even thought of removing the dome light and just using the lens as a cover but it gives me a 3" x 5" opening which won't help. As for it being a new truck...yes the wife is not happy with the whole drilling holes in it thing...I'm also thinking about a roll / light bar as an option.
Don't really need to run ground straps off a Tri-Mag mount. Before turning my Suburbans roof into swiss cheese, I ran a Tri-Mag mount with my Predator 10K for several years...(no ground straps.)
Another option would be to mount a riser in the back, and stick the antenna on it...There's several hear that will tell you this either "won't work" or is not a good idea...Well, it may-not be the "Ideal" way to mount the antenna, but it works fine for me...I get out just as well locally with the antenna mounted on a riser, as I did with a mag mounted 10K on the roof. Plus even just running a little 2-pill I can still get my name called in DX.(when there use to be "DX")
In these pic's the antenna I had on was a Monkey Made "Big John", but I have a Predator single-coil back on now.
JJD better watch your roof line that many pluses could increase your taxes.
My preference is headache rack with hard mount. But, I do understand "it's your wife's truck" not yours, and she allows you to use it every now and then. :whistle:
All pickups should be equipped with an aftermarket headache rack and truck box. Gives you access to pack a ladder, 2x4's (wood), long objects without fear of tearing up the roof. The box allows for tools, tow chains, emergency gear, in a lockable place without taking up cab space.
Reactions: Slowmover
Careful. One might make a softball Daddy uncomfortable with all that testosterone.
Thems don’t know Class 1 from Class 3 safety gear. Mud boots from snake boots. Confined Space Certificate from Protection Orders. Etc.
They use words like, “kernel”, and, “root”, in ways my Nebraska farmer great-granddaddy would never cipher. Same with, “curate”, and, “apple”, would cause my Phi Beta Kappa grandmother to go silent.
Ask them the First Gear torque multiplication.
Pretend to have had a frog in your throat they look confused.
They drive “pickup trucks” (emphasis on latter). Buy custom $700 packer boots and Filson outerwear. Pull $120k Living Quarters horse trailers at 77-mph, weaving thru traffic with purebreds in back. Discuss beard cream at the dinner table.
You and I drive pickemups (Ha!)
Yup! Kin jus figger den turn'n nose up to anyone say'n...."You git that "root" in that pipe yet?"
Much less even unner stand what a "Dog knot" is.......:eek:
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
