8 ohm dummyload
Or one of these;
https://www.ebay.ca/itm/Chassis-Mou...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
All over ebay. You need a 8 ohm load when testing a lot of audio amps. So just look for audio or stero amp dummy load.
https://www.parts-express.com/8-ohm-100w-non-inductive-dummy-load-resistor--019-020
https://www.ebay.com/itm/1000W-2-4-...hash=item1a2415b534:m:m4OqzC9ficZ3OQncCRlqFcw
I doubt you want a reactive load simulator. http://www.aikenamps.com/index.php/dummy-loads
Hope this get's you started. I know you are working on a radio but when I buy something I like to think ahead so I can get all my moneys worth out a piece of gear.
Reactions: Tallman
https://www.parts-express.com/8-ohm-100w-non-inductive-dummy-load-resistor--019-020.
You only need a eight ohm, ten to twenty watt NON-INDUCTIVE resistor. The inductive resistors will affect your readings. That is normally done for the receive alignment.
With a set RF voltage and frequency going in you need to have a certain amount of audio watts output and you peak or dip the watts as the test procedures direct.
I wonder how inductive the coil of wire in the speaker is or the random length of speaker wire. CB shops will be selling scope tuned jumpers for your external speakers now. :whistle:
You should see the crazy stuff they sell to audiophiles as speaker wire! Not the stuff we used as kids or teenagers that is for sure! You could jump-start a diesel with some of this stuff! LOL
I have some pretty intense speakers from the 1970's through the early 1990's and all manner of tube and solid state discrete amps and I do not use anything too exotic! LOL
The voice coil of a speaker is inductive enough to have its rated impedance at audio frequencies (usually around 1KHz.) 8Ω speaker; 8Ω impedance. You can calculate the inductance (in Henries) from the inductive reactance.
