Its for my cobra 29ltd alignment procedure calls for 8ohm dummy loadSix 47 ohm resistors in parallel.
The radio's speaker is either a 4 ohm or an 8 ohm; so be aware.
You only need a eight ohm, ten to twenty watt NON-INDUCTIVE resistor. The inductive resistors will affect your readings. That is normally done for the receive alignment.All over ebay. You need a 8 ohm load when testing a lot of audio amps. So just look for audio or stero amp dummy load.
https://www.parts-express.com/8-ohm-100w-non-inductive-dummy-load-resistor--019-020.
does it equal to 8 ohmsSix 47 ohm resistors in parallel.
7.82 ohms - which is more than enough to be accurate for testing purposes.does it equal to 8 ohms
I made the dummy load works well thank you.Six 47 ohm resistors in parallel.
You should see the crazy stuff they sell to audiophiles as speaker wire! Not the stuff we used as kids or teenagers that is for sure! You could jump-start a diesel with some of this stuff! LOLI wonder how inductive the coil of wire in the speaker is or the random length of speaker wire. CB shops will be selling scope tuned jumpers for your external speakers now.![]()
The voice coil of a speaker is inductive enough to have its rated impedance at audio frequencies (usually around 1KHz.) 8Ω speaker; 8Ω impedance. You can calculate the inductance (in Henries) from the inductive reactance.I wonder how inductive the coil of wire in the speaker is or the random length of speaker wire. CB shops will be selling scope tuned jumpers for your external speakers now.![]()
