HAVING ISSUES WITH THE SITE
Sonar
Apr 8, 2016
1,501
1,022
173
I can't pull up the menu. Nor can I access any replies to my postings or private messages using either icon.
I tap on the icons and although they Flash as if the menu is going to slide across the screen from left to right as it usually does, but nothing happens. Tapping on the replies or the pm icon is also flashing but not seeing the envelope that contains PM'S or replies. Any ideas? Thanks.
When I hit the red notifications box at the top of the page it takes me to the wwdx homepage. I'm using an android phone. Other than that everything seems normal.
Is there anyway you can take a screen shot so I can see which notification you're referring to? I have a lot more notifications than most so I'm not sure which one it is.
Sure. It's the red box that says 2. The menu does not work either.
If I change my browser settings to desktop view it works.
Is it better now?
Moleculo. I'm still having the same problems.
When I tap the menu it flashes once as if it's going to show up, but it doesn't.
My red box is reading 13 and I still can't access it.
I tap the icon and it brings me to the page that begins with members featured photos and whatever else usually follows below that on the page (featured articles ect ect.)
The two ways I'm able to access my PM's is to tap reply on my email notifications.
I don't use a PC.
I'm using an Android smart phone.
I restated my phone.
Then shut it and turned it back on. It may sound silly but it's the only thing I could think of that might have helped. It did not. I am accessing some some choices from the three little dots that are horizontally located a bit to the left and below my p.m. and post reply notifications icon. any ideas on how to rectify the issue. I'm not smartphone literate. If you have any ideas please lay them out in layman's terms. My speech-to-text is and has been acting funny 4 a while now. The speech to text problems or issues are only happening on this site. That's actually actually not as important as the other two issues. Thanks
I don't use a PC.
I can replicate this problem on my phone as well. I know what the problem is, but I haven't figured out how to fix it yet. The work-around is to tell your browser to request the desktop site until I can figure out the fix.
FWIW I ALWAYS load the desktop version on my phone. I guess It's just because I used a PC for so long the appearance of the sites is familiar to me. I HATE mobile versions and apps instead of the full versions.
