Galaxy schematic-959 duel final
many have done it, and i have a "tutorial" of sorts posted somewhere here on the forum, but it's not a simple plug-and-play type of mod.
It takes some work and tuning to get it to work right since all radios are a bit different.
so, you may install it and it works like a charm, or you might install it and find that it acts like the second final isn't even there.
If you don't have the skills to know what to do if/when this happens then i would not recommend trying this mod.
sonoma, i think the links you provided are for radios that start with bipolars in place.
I believe Larry is looking for a mod sheet that lays out how to turn a single MOSFET final radio into a dual MOSFET final radio.
Got it covered. I have been troubleshooting and repairing radios since the early eighties.
cool.
all you have to do is compare the schematics of the mosfet version of the DX959 to the schematic for the mosfet version of the DX2517 and add the missing parts.
(found here: http://www.cbtricks.com/radios/galaxy/index.htm )
other than that, there is a jumper to add which should be pretty obvious from comparing the PC board layouts, and you have to convert L35 from a 7 turn coil to a 4 turn coil.
Thank you. That is the solution I have been looking for. I was not aware that they were the same board. Fantastic. After I do one I might make up a kit for sale on eBay.
cool.
Larry, all i can say is more power to ya with regards to a kit that yields consistent results.
This was popular and sought after about 10-12 years ago, and there were a few who had kits on ebay for this.
the problem is that each radio is different and each radio has to be made to work with this mod in some way.
some radios may wake right up with just the requisite components added, but some will just ignore the second final as if it's not even there.
these radios need to be worked on by someone who understands the concepts behind the mod, and basically, anyone with the knowledge to make it work consistently won't need to buy the mod because they will know how to figure it out for themselves.
If you do decide to put together a kit, be sure to try your method in a BUNCH of different DX959's so you will know it will work.
please post back with your results!
Reactions: Slowmover and NZ8N
this is a lay out for the dual mosfet final setup. yes I know what he is wanting to do but this will help him see just what he needs to do to convert the radio to dual finals..
I have used this layout 3 times now and only 1 time I had a problem getting the out put past 20 watts. Rick from euro radios helped me to get the radio to put out more.
this layout drawing will help you to see just what is needed to fill in all the empty spots.
http://www.cbtricks.com/miscellaneous/fet_papers/mosfet_conv/graphics/6900xxx_ssb_mosfet.pdf
you're right Sonoma, that is a good layout to have around when experimenting with this mod.
I think i actually used it when i developed my personal version of it way back when.
