Coax length?
85Blazer
Nov 8, 2017
24
6
13
56
I just was wondering what is the max length of coax I can or should run? The reason being I just got a solarcon a99 and I'm trying to decide where to mount it. Any thoughts?
If your antenna is 55' away, but someone tells you, you can only use 50', "what would you do?" Stick the radio out on the side of the tower?
I have several coax leads all are around 160ft. I will stick and antennas high as I can get it into the air. My A99 tip is 108 ft. in the air. It is all about how you can improve the signal. Off grid in the boonies in the mountains is me all the way, and always trying to better the signal in and out.
Old note in The AARL Antenna Book, Hall Edition, page 111 has some information that may be of use to you. The diagram shows Length in Feet to avoid exact resonance at frequencies from 3.5 to 29.7 MHz. Although it's disputed, remember this was probably printed from actual lengths that had been used without the use of antenna match boxes. I figured my length needed and just so happens it fell on one of the "best match" locations.
Reactions: Rwb
If we lived in a perfect world where coax had no losses, then it wouldn't matter. However, it really does depend on how much loss you are willing to accept.
Lets say you are transmitting 100 watts into 100 feet of:
Belden 9201 (RG-58) you will get 63.29 watts out
Belden 9258 (RG-8X) you will get 69.854 watts out
Belden 8267 (RG-213) you will get 78.543 watts out
Times Microwave LMR-400 you will get 86.403 watts out
NOTE1: Data above from https://www.qsl.net/co8tw/Coax_Calculator.htm
NOTE2: Data above assumes a perfect SWR match at freqnecy 27.18 MHz.
So to answer the question of how long of a coax run you can effectively use depends on the length you need to run and the type of coax you plan to use. With the example of the Belden 9201 RG-58 coax above, after 100 feet of coax you have effectively lost over 1/3 of your transmitted power before any of it ever makes it to the antenna.
I guess what I am trying to say is, to give you good advice, we really need more information on the type of coax you plan to use and the different lengths of coax needed, as well as the different heights of the antenna in question.
The DB
Do you think between 63 and 86 watts the receiving end can hear a difference?
I love the assumptions being made...
Here, let me put your mind at east as you have clearly not seen the many times I have talked about such things in the past.
No, I not only not not think, but I know that a receiving station won't notice this difference. But then, that wasn't the goal or point of my post to begin with...
I was simply trying to show a potential difference in a way that someone who is not as technically minded as some of us could understand, and use that as a springboard to ask for more information so we can provide better guidance.
The DB
I knew the answer and what your point was, was just throwing it out there as some might look at it in that point of view
Reactions: Rwb
