A Winner has been chosen for the 2026 July 4th Retevis RA89R Giveaway! Click Here to see who won!
Ok got everything hooked up except 8v transmit wire hoping someone could chime in a help me out with it. Tr23 has 13v it's a 2015 cobra 29 nw ltd classic thanks guys.
The ones that came with it from palomar bought it from bells. Yellow coax to antenna wire board connection red coax to antenna connector sheilds tied to can. Red going to + input ground - input blue wire to 8v on tx. That's the one I have left to hook up
You are correct sir thanks again therealporkchop. Getting this rfx in the nw and then put the 60 in the wx nw st. This forum is great thanks for the help guys
Got it fixed up. 18w carrier. Now just to tackle my interference gremlins getting interference and poor receive. Going to go over my solder joints. Also installed trb x-3 so can't rule that out either
Where are you guys pulling your 8 volts from in the galaxy 959 chassis? I normally pull from the vacant 8 Volt source near the audio ic where the roger tone on/off is for echo boards. Just looking to see where some of you fellas pull 8 volts from for these rfx gigs as I know there are probably 100 ways ands better ways near the install area
