FROM 73-87 THEN 2015-19 NEVER HEARD THE MINI EXPLOSION THAT LETS THE MAGIC SMOKE OUT. UNTIL
Sonar
Apr 8, 2016
1,502
1,025
173
I never run the Palomar 350Z in the high position. The reason being is that with 2 Watts DK and 13 pep I get 125 DK and 500 pep (in the low position.)
The only thing the 350z does differently in the high position is gives me a dead key of approximately 300+ Watts with the same 500 pep.
I just wanted to run it in the high position for a few minutes. Unfortunately I forgot that it was indeed in the high position for the two hours I spent on the air that day. On one key down I got long-winded. And I guess you could say I popped my cherry. For the first time in my life I actually heard a noise startling pop. It wasn't an explosion. There was no smoke nor smell. But there's certainly was a pop. And a pop loud enough to stop my heartbeat for a second. Okay I'm going to be honest. The pop almost made me shit my pants. This is what happened and in my opinion the person who repaired it did a wonderful job. He not only repaired the pop issue but did several other things as I did give him carte blanche to do whatever he needed to get the 350Z not only in working order but if possible better working order then it came from the factory. I never thought to ask him to get the preamp working as I never use amplifier preamps anyway. Although I must say after trying it two days ago while some slight skip was rolling in from Florida the 350Z and it's cheesy preamplifier actually helped pulling in a station that I made contact with. I most likely would not have made that contact had I not been for the option to use the preamplifier. There was several other things he did to the amplifier that made it a better working amplifier. I'll just stick to the original post at hand. This is what the loud pop was.
Three capacitors burned up. I don't know which one of them went pop. But the one that did go pop obviously caused to others to melt down.
This is the repair photo
As you can see he didn't just replace the blown and burnt diodes he added a component that I can only assume made an improvement on the original design in that area of the amplifier.
I run the 350Z in the low stage and even though I believe he said there would be no issue running it in the high position he also suggested what I believed from the beginning was that there's absolutely no reason to run it anywhere but in the low side. The only difference is the 200 what dead key while running it in the high position as opposed to the low. Most of us know that is not going to make a difference on the other end. The only thing it could do is put unnecessary stress on 40 year old tubes. Tubes that cost between 50 and $70 each if you can find them. Then you have to hope that the seller is honest. I think many people purchase tubes that are probably no better or worse than the ones they're replacing. The six tubes in this 350Z are still showing full output with excellent audio reports from the transceiver I'm currently driving it with. 2 watts DK and 13 pep seems to be keeping the amplifier happy. This amplifier had the b+ relay modification added to it many years ago and runs nice. It doesn't get any hotter than 6 sweep tubes should. The cover is slightly warm to the touch and as long as I keep the key Downs under a minute (ideally 30 to 45 seconds) the temperature will not rise that much. I tend to be long-winded but I'm trying to teach myself that you just can't be long-winded when using these old sweep tube amplifiers. I would venture to Guess that being long-winded even with a newer amplifier that doesn't use sweep tubes one should be careful at how long they actually key down and modulate. Anyway. I just wanted to share my first capacitor explosion/pop story with you guys. And show the before and after pictures in hopes that those in the know will tell me if they think this was a good repair. He also repaired the mfj 828. It finally works the way it should. I sent it to him without even letting him know I was sending it. I had some extra room inside the shipping box for the 350Z so bubble wrapped the 828 and sent it along. I'm not sure what he did but he did not charge me. I'm going to send him both my wm1's as they're both showing different readings and either one or both most likely need an alignment. God bless. 73's
When high voltage goes BANG it can do wonders for boosting the heart rate. BTW those are diodes that blew not capacitors. At least your repair guy knows how to solder well. I have seen a LOT worse.
Reactions: BJ radionut
The only reason it still works, IMHO.
Gotta love it when a plan comes together.
I understood that modification was important but didn't realize how important.
Si. The 350z's that didn't have that particular mod done are most likely compost at the bottom of some local landfill? The Palomar 350Z is the least popular out of all the sweep tube amplifiers I own. I'll fire it up now and then just to keep the diuretics fluid. I am only using it because of the repair that was made to it because of the pop when the weasel. I have a list of the other improvements that were made to this 350Z and in all honesty it has never worked better. I actually never addressed the issue as to whether or not the technician I sent it to should repair the preamp. I did basically give him carte blanche and although I didn't mention the preamp never thought I would get it back with the preamp working. It actually works fairly well. Although I'll probably never use it one never knows. There might be that one station where one s unit or less will make the difference between making the contact and not. I have been leaving the preamp off but occasionally flip it on when I hear a distant station. And believe it or not it actually works! I will be using the 350Z until I get the Phantom back. I added a another o p and hope that you reply to that particular one. It pertains to my Phantom and the amperage that is drawn by it. It also exes the question as to whether or not the 6JG6 what is a driver or does something else in my particular Phantom. Thanks nomad. 73's
High voltage smells like chicken. High current smells like barbecue.
Besides the POP there was no smoke or smell. Concidering the photo that my tech sent me before the repair I was surprised at the lack of smoke or smell. I guess stranger things have happened. Looking at the photo one (including myself) would find it hard to believe there was no smoke or smell. But I guarantee you there was neither.
I believe you. One time I cratered a chip and there was no smoke or any warning at all. Just a loud BANG!! and the circuit stopped working. On closer inspection I could see a crater in the top of the chip that looked like an open pit mine. LOL
