I've tested 2SC1969, 2SC1307, 2SC2312 to destruction .
I have never seen any useful power over 18W for any significant period of time with anything close to acceptable IMD or even approaching a linear amplification characteristic.
If you want more from a 29* Talk to Nomad about a peel and stick carrier control and buy, build, bowwow, steal a broadband 2 device BJT amplifier. A 2SC2290/2SC455 pair will accept 4W a 2SC454 pair a bit more and the 2SC2879 still more but do read the data sheet.
As for RM- Spaghetti and their fustercluck of plastic cased FET's of dubious origin you are on your own. In the time it took to write this 4.5 more of them died an instantaneous death due to force feeding their input with a steroid saturated radio.
There is one easy way to get a few watts out of many radios if you actually understand RF I/O .
Yes it's a HR-2510. So what ? It's driven with a 2SC2166 as well. It does have somewhat more heatsink area than a '29 but if you're doing these hotrod mods you already installed some sort of additional heatsink. (you did , didn't you? )
Oh ? You can't find 2290's, 455's, 454's 2879's or even the 2SC1969 anymore? (at least not reliably and economically)
Welcome to the new century. You have about 20 years of catching up to do.
TANSTAAFL
MosFets, LdMos, and a correctly aligned dilithium matrix are the new millennium boys and girls. Get on board or get left behind....
Agreed and kinda my point. Nitro engine that you rebuild every 4 seconds or a healthy daily driver. Daily driver of course means different things to different people.But don't blink, because it won't be for long. And only if the output circuit has been tweaked to match the lower collector impedance this brings about.
The positive peaks of your modulation audio can reach 30 Volts peak in a radio that delivers that much audio power to the final's collector circuit.
I did this mod with a uniden 76xl and I get backswing when my variable power is all the way up on an external meterI was asked by a few people how to do this mod, so I figured I'd just post it up.
Please don't copy and paste this mod to other sites/forums, but feel free to link to it.
Also applies to:
Uniden 78
Cobra 25 & Uniden 76 mod is similar, although you'll need to cross reference against the schematic.
1: change the final to a 2sc1969
2: change the driver to a 2sc2314.
3: change the electrolytic capacitor by the audio IC (C42, 1000uf) to a
3300uf, 16v.
4: Take a turn off the output tuning coil (see tuning coil note below)
5: Remove the AMC potentionmeter (VR4), and put a 1K resistor in it's place.
(only two connections are used on this pot, use those two connections
for the resistor)
6: add a 1K in series with D11.
7: Change R48 to a 33K ohm resistor.
8: Change R55 to a 10K 1 watt resistor.
9: change C37, and C68 to a .2 monolythic (this changes the A.F.
response on TX)
10: Now align the radio, start with the output coil, the the predriver
stage for peak output.
11: Tuning notes: Tune L17 for max with audio. Then, tune L23 for max output with audio, this will upset the radio's frequency. So, after L23 is set, adjust L24 to put the radio back on frequency.
Tuning coil note: If the radio says "made in China" on the back, you must remove 1 turn from the output tuning coil with the slug in it. If it doesn't then you may or may not have to. Count the turns, if it has 4, leave it alone, if it has 5, it's too many and won't tune, remove a turn. You may have to add a 68pf capacitor from the left terminal of the coil to ground, with the solder side of the board up. This method produces better results than just removing the tuning slug.
This mod will consistently produce output between 10-12 watts AVG and 45-50 watts peak. If I can find my video clips of Bird 43P power meter and spec analyzer I took after doing this mod, I'll follow up with those.
If it doesn't look good on the 'scope, it's not a good mod.if what to see 50 peak it is called a comp mod the mod is change drive to a 2sc2314 final to a 2sc1969 jumper r123, r58, d8 remover r55 add a 500pf to a1000pf to c62 it wont look good on a scope
