Ameritron 811 and TS-590SG
Mudfoot
Elmer
Jun 17, 2009
11,296
6,713
698
64
Southeast Ohio
Found a local deal on an 811. Only base amp I ever had was an old Johnson Viking. That was way long ago. I want to use it for 10 and 40. Will not be using a tuner. What is the absolute equipment I will need, beside the cable? I can make the interface cable. Do I need anything else? I want to be minimalist, but want to protect my rig and amp. I remember something about the older 590's having an amp keying issue, but the latest model doesn't.
Reactions: binrat
I have the 590SG and also had the 590S. Neither one had a keying issue that I was aware of.
I do use the Ameritron ARB 704 as a protection buffer and simple 2 cable interface . Not really necessary but not a bad idea to use one.
You do have a menu settings for amp keying for relay on/off /delay on your radio.
You should be good to go!
Reactions: Ranch55 and Mudfoot
The 704 is cheap enough, I suppose.
Reactions: Ranch55
He wants $500 for the amp. Says for $75 more, he'll throw in a new set of 572's. Is this something I should get? Said they'd take more abuse. The amp hasn't been modified for 10, YET. He only used it on 75 meters.
Sounds like a deal!
Those tubes are easy to come by.
Just checking, you did order the Kenwood interface cable for the ARB 704?
It says it a universal buffer. One reviewer said it comes with necessary RCA cables. Ordered it from Amazon.
It takes a radio specific cable from ARB to radio. RCA cables are used from ARB to amp and ALC(if ALC is needed ).
No power cable needed
You need the PNP-7D cable
Reactions: Mudfoot
Yep, I just read that. I just ordered that cable. It should go out in the same order. I went ahead and told the dude I'll take those tubes. He got them from DX Engineering. Says their unused. Figured at that price, I could sell or swap if I end up not using them. Do these cables provide power to the buffer?
Thanks for catching that.
I noticed the cable doesn't list the 590 but it is it. It goes into the 7 pin ACC jack.
Looks to be in near mint condition. Very clean inside. Fan blades clean. Looks like it was a desk princess.
I didn't look for the green wire, but it's gotta be snipped.
