A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
This forum is the most fun place to be. I picked sweep tube amps to learn on, they seemed basic .not like a radio . just amplification and a good place to learn the basics.
I think of mini/RG8X as a compromise. Better loss figures that RG58/U but smaller than RG8/U. The real trick is knowing what length you need to run, what power you want to run and what loss is acceptable... then make the decision.
RG8(9913) 9913 This coax cable provides excellent performance for high power HF needs or VHF/UHF applications. Because of its solid center conductor, it is rather stiff
Impedance: 50 ohms Power Handling: 2200 watts 30 MHz and less
Attenuation: 0.8 dB per 100 ft at 30 MHz and less
