What Frequency counter do you guys recommend
I would not bother unless what you really wanted to start with was just a display.
You changed your original posting.
Reactions: Crossbow
I figured it was junk but wanted to see what you guys thought about it to make sure.
I did not change my original post?
As Tallman pointed out, I would also go with Hp. Thing is, to be reasonably stable, you must be sure that it has a stable 10mhz reference TXCO. Some of older ones don't have that and require an external 10mhz reference source.
Thanks for the heads up!
