Surface mounr resistor question.
Low_Boy
Jan 21, 2010
1,937
1,208
173
Rochester N.Y.
I need to replace a 10 ohm 1/8 watt surface mount resistor. The original is a resistor that has stripes like a through hole. All the new surface mount resistors are black with a number in the center and two solder pads. Will they fit where the striped one came out? I can not find any like the old one.
Thanks.
Thanks.
As long as it's the correct value and it will fit in the spot it will work
