Surface mounr resistor question.
Low_Boy
Jan 21, 2010
1,931
1,193
173
Rochester N.Y.
I need to replace a 10 ohm 1/8 watt surface mount resistor. The original is a resistor that has stripes like a through hole. All the new surface mount resistors are black with a number in the center and two solder pads. Will they fit where the striped one came out? I can not find any like the old one.
Thanks.
Thanks.
As long as it's the correct value and it will fit in the spot it will work
    63Sprint has left the room.
