Diamond SX200
RT431
In the swamp
Dec 2, 2018
861
1,629
253
Nebraska
Anyone have any experience with this meter or any of the Diamond meter's?
I'm in the market for a new meter and asking for opinions. Thanx!
RT431,
I have a Diamond SX-400 for 2m and 440. Had it for about 25 years or so. Never a problem with it. Can't remember the initial cost but did buy it new.
I have often thought of getting another for HF but............................I need another HF meter like Undertaker needs another radio, or mike, or antenna(y)(Love you Bobby!)
David
Reactions: Ranch55 and RT431
I have had the Diamond SX-1000 for a LOOOONG time and love it. It is accurate but do not believe the pep function. It is just a capacitor that holds the meter higher and has no active powered pep circuit. Other than that it has been a GREAT meter.
Reactions: RT431
My SX-400 will not work in the PEP mode without power applied (through the wall wart).
Hmmmm. SX-1000.....SX-400? But I have only had mine since 1993. Not such a LOOOONG time as CK.(y)
Regardless, I like the SX-400. It is compact (doesn't take up much real estate), seems accurate and the meter is lit (better for the Senior eyesight).
David
Reactions: RT431
I had been looking at the 200 for the simple fact as Dmans stated, it takes up less realestate than some other meter's.
Also, I think it would look awesome above my SS9900. :)
David
Your SX-400 does not read pep accurately. It is just like my SX-1000. The power supply is simply for the meter light. Take a look at the third note in the manual here. https://www.diamondantenna.net/pdfdocs/SX200&400.pdf It only reads 70-90% of true pep due to the CR circuit. The CR circuit is a Capacitor/Resistor that changes the time the meter stays at something NEAR a peak value.
Reactions: Dmans
I have had my SX-1000 since even before I had my ticket which I got in 1989 so it is at least 30 years old. I got it because I have only even run 100 watts and it covers HF/VHF/UHF all the way to 1.3GHz. I was able to use it even on cellular bag phones way back in the day.
Reactions: Dmans
I've never had a problem with the Diamond meter's I've owned (hf/vhf/uhf)(y). I'm using both SX-200 and SX-1000 versions. For just HF, the 1000 is overkill, I mainly use that one between my TS-2000 and vhf-uhf antennas.
