Part needed for Turner Super Sidekick Microphone
Jim1428
58
29
43
76
I am looking for a Motorola chip for this mike, part number is MFC 4000B.
I have found several places on line selling this part or the equivalent for $20.00 or more, is this the going
rate or can it be obtained for less?
Any suggestions would be appreciated.
Reactions: 357
I'd buy a beater off ebay and swap the chip
Reactions: RT431 and Woody-202
Try a lm386, that's what the sidekicks i have seen had in,
It might work, the Motorola chip is a 4 pin device, the lm386 is 8 pin, looking at the data sheet the schematic is similar, I will compare both schematics for compatibly.
Thanks for the tip.
im guessing turner made 2 versions of the board,
i remember looking in my ssk and thinking they could have used a lower noise lower output opamp rather than something more commonly found driving a speaker in low outout audio devices.
i never did hook a loud speaker up to see if it really would drive it to a reasonable sound level.
good luck
good luck
I am going to try the lm386 just for grins, it may work better than the original, you never know until you try it.
