Hey Wire WWire Weasel I'm curious.
Did your Venom tuneup with the overall length of 19' feet as you stated above, or does it allow to tune by adjusting the top element length a little?
If the kit allows for a little tuning range, do you know what overall length you you ended up with...as measured from the bottom of the mounting bracket to the tip?
Otherwise, if this kit is fixed construction and not tune-able, do you know the frequency where it shows the best resonance?
If the manual shows bandwidth for this antenna, do you know what your antenna shows for <2.00:1 SWR?
Did you see Marconi' s Question?
I am curious about the length thing too.....
