Maverick
Hello all,
I need some help With an amp I got in a trade deal. It is a D&A Maverick Dual Power 4 band amp. Cant find any info on the web, only the grey Maverick 250. This is a tan front with a brown case like the bigger amps, and has a switch for 10, 15, 20 and 40 meters. It is an 8 tuber, with 4 6JT6a's driving 4 6LQ6's. Can it actuually be used on those bands or is it strictly a 11 meter amp? Drive? Output?
Any info would be appreciated.
Thanks in advance.
PR
I don't think it will work as it should on any band accept 11 meters. To my knowledge it will work on those other bands, but not correctly. It'll most likely show very low output on anywhere but the "10" meter band option.
if it has a band switch then yes it can be used on those bands .
they like a 4 watt input with no more than 50 peak swing .
output with good tubes is near 1000 watts peak or 400-500 rms watts.
i have a copy of the maverick manual that gives some specs and tuning info .
drop me your email in a pm and i can send it to you later tonight.
Fnkycold medina can I get that d&a maverick manual to please... fla.guy223@yahoo.com
