Now, here's the answer to the 2nd part of your question...
When the discussion talks about noise abatement in a CB receiver, and then the talk gets very complicated and technical, and then it's claimed that the beneficial effects of bonding might not be detectable just by listening to your radio...I have to wonder why.
It's not a real answer, but it is worth mentioning...
The K0BG site mentions the AGC and leaves us kinda confused on the - "Well I did all this to get rid of the noise, but now the radio doesn't seem to really "reduce" noise all that much..."
The answer to that is, - the radios ability to receive - dynamically - stations that may have signal propagation effects occurring while the signal from that station is arriving and being processed in your receiver.
Such things as reflection - multipath arrival of a signal from the source.
It generates an interference pattern both in reflection off of objects, thru the environment and also arriving to the antenna, and also can ride along within the signal path, it's noise radiated close to the reflective area bouncing the original signal towards you - in AM, you don't truly hear the effect, but you do get noise.
So you have to understand that the noise you are hearing be it local within the vehicle, or external outside being picked up b y the antenna - the dynamics of the reception and the signal strength of everything in proximity to the antenna and the radios' ability to properly amplify and discern a specific frequency and or station you want to listen to on the frequency - is more of the concern. If the noise still covers it up - then you have more work to do - get back to reducing the noise floor of your station.
In regards to the interference pattern and wave cancellation and reinforcement - the "flutter" itself is why we have AGC - it is so the reception of a signal can be made consistent in amplitude or capture in bandwidth of frequency (as in FM modes and SSB) so you can hear the intelligence on it.
So when it comes to the ability of the receiver to handle this widely varying signal, amplitude and in the noisy environment it is being put in to receive that signal - you need the receiver to be able to not only "open it's ears" to get that signal - but as that signal and all the noise in it's environment arrives to the receiver, to keep it from "crashing into your cranium" - uncontrollable volume, amplitude and in some instances can even damage the receivers' circuitry from the excessive amplification.
So the makers use a principle of feedback - to control the gain using the signal strength received, detected and can measure it as a source of power for, applying it to SPECIFIC sections of a receiver to control the gain and handle the dynamically changing conditions of the environment you are operating - receiving signals in.
For a Cobra 29 - your CB radio will vary
Ok, note the above, for it's a CONFIRMATION as well as a CLARIFICATION on how we should perceive AGC and the noise level we don't seem to be taming - may just simply be the effect of the Receiver enjoying, employing the effort it was designed with and now AMPLIFIES the noise level present - what you do not perceive is this effort of the noise - seeming to be the same, may now simply be a remnant of the noise captured originally mixing in and COMPRESSED into the audio and RF signal envelope captured by the receiver.
Note AGC is a simple voltage divider used as a summation - which the result is then applied to both an IF amp to offset the gain across an Emitter Resistor - and the RF Gain as an amplifier to control the PIN diode attenuation of the input signal.
Input signal: Meaning Everything - Noise inclusive.
- On a segue - The RF gain uses the AGC power as a means to control the amount of signal (Noise - et al.) to maintain a relatively consistent level of input. This keeps the RF Amp working as well as offering the ability of the IF section to properly discern and strengthen the signal you wish to hear.
- Failing to keep the input signal within limits - you can damage the receiver let alone experience poor performance and inability to hear stations because of the distortion of excessive input signal strength placed upon the RF amp - and subsequent stages following it.
The clarifying comes into this from the fact that IF signal is controlled by AGC, but not as the overall one solution to this complex problem - for if we simply used IF amp as the means to control the processing - what would happen to the RF amp if it received higher than expected noise and EMF/EMP impulses from a lightning strike nearby - potential damages can result if the system doesn't use some form of attenuation to control and to provide for a means of protection from such events.
- So as clarity, the IF is using AGC to help control signal level in processing.
- AGC is also NEEDED as a means to help the radio receive signals that if not controlled in volume - envelope or it's impulse and noise level the receiver is being used in - can damage the radio.
- You can't have one without the other - in regards to AGC; BOTH IF and PIN attenuation are used.
If you wish to try an experiment - then simply sub in a variable 50K potentiometer on both R31 and R35 - control them separately.
What you can attain with this - is to learn how AGC can work, by turning lower (Reducing) the resistive value of R31 - makes AGC aggressively to push down noise floor, and if you restore R31 back to original - adjust R35 - to make AGC passively open up the receiver to it's full performance potentials -
but exercise care in these adjustment ranges - for you can damage the radio.
