Word on the street is dei transistors are vswr sensitive. Keep it lower than 1.3. No "volting" also. Keep it cool and it should last a long time.
I just finished drilling my dx1600 lid and installing a fan kit. All repainted and back together. I too have some wiring to clean up lol.
So how do the "Steel" tubes stack up? Are they as good as the real thing, or better than nothing?
Do you mean 3:1 or 1.3:1? Nothing wrong with 1.3:1 with a well-designed amplifier. "1.3" isn't a ratio.Agreed but find a good used one as it seems ts is using a Chinese Toshiba 2879 look alike transistors lately. Word on the street is make sure your vswr is no more than 1.3. That goes for hg or dei units. Do not volt them.
1.3:1Do you mean 3:1 or 1.3:1? Nothing wrong with 1.3:1 with a well-designed amplifier. "1.3" isn't a ratio.
The amp isn't finished. I did order a window unit AC for the garage so I can ge back to business.
Curious...
Would you still need AC for the Winter season?
Now don't laugh guys seriously - the winter air and it's moisture content may accelerate issues we normally don't think about...Sealed systems for dust and humidity retention kinda' conditioning.
Nice work - and yeah, you don't want sweat acting as an accelerant for rust and corrosion.
Looks like a Sweet project - Big plans soon?
Wow, you should start a build thread.The wd40 is holding up well. I'm not going to paint it until it's done. Then I can rip it all apart and paint. The ps is mostly done. Just need to finish the rf deck and metering. Garage built CB junk with a different tank coil.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
