Hmmm...Good question...
A good way to understand this, is to look at the "Datasheets" the Final and Driver are "classified" Cataloged or otherwise specified...
The "Device Under Test" Circuit only produces so much data, the rest is how you utilize the transistor, OR MOSFET, to operate in a non-linear, but linearly - power curve.
Some Datasheets provide a Bias design for their specific part, but it is RATED for that particular Bias as a factor of Class Of Operation - Conduction Angle or duration the part is on, during the Single-Sine Wave cycle (if you think of it that way - it helps to know the time on to time off as a percentage or 70% Duty cycle - or 70% conduction angle) - as an example.
This is what makes the "Swing" part - the rest is what is "Tailored" by you or your tech, to produce a given envelope of power around this effect.
Now, I said "effect" because that is what you're doing, is utilizing a part to generate a wide power curve - in a narrow range of power level "change" on it's input.
The Transistor has a Characteristic Impedance, a reaction - to the amount of input power being applied to reflect - mirror, amplify - the power that is produced on the output. A series or sum of Vectors, both in phase of Voltage and Current, as well as it's "power level" at that moment in time in the Input power - then can be processed by the PN junctions of the Transistor - to produce an output mirroring the vectors with characteristic changes caused by the processing the transistor places itself under... Remember that RF or any form of AC signal; be it RF or even audio - works or vectors with - Inductive and Capacitive effects that are part of the power curve. So if you need to reproduce any RF wave - you need to allow for and account for the Transistors willingness to cooperate or alter the waveform - either faithfully or destructively.
Same can be applied to Linear Diffusion (or device) MOSFET designs - that are made to offer a region, or power level - that isn't fully on or off, but works like a transistor - but offers a different input impedance. Being much higher, can't process current - but will provide large amounts of current swings (draw amperage) as a relfection or mirroring of the inputs..
To overcome this limitation - a voltage component is used - in Bipolar design - they require current - but in both parts, some voltage is necessary to overcome the inherited characteristics' like "voltage drop" that will affect how the power curve develops - a factor of Class Of Operation. - Class A being the most faithful reproduction at a cost of conduction and power dissipation on down to lower levels of conduction - Being Class B and following the letters of the Alphabet. Class B the next most "faithful" while latter Class types are placed below that in levels of conduction the parts produce.
So to put this in a light of what we do with CB radio, we try to force the carrier from being a "Steady state" constant, into a variable power curve we tailor to suit the needs of the customer;
- be it audio drive, or power level - you can change the operation of Class by changing parts in the Amplifier stage to achieve these various effects.
