Solder/Crimp pl-259
Eldorado828
828 in the Lonestar state (WDX-828)
Feb 21, 2016
4,830
9,603
523
The Panhandle of Texas
I've used these (rfc) 20201111_221451.jpg for a few years now and they work really well. Silver and Teflon with good quality build. Well I ran coax in the truck last week and used the last 2 and the seller is all out of them.
So I'll ask you fellas that also use this style of UHF connector, what do you use and where do you recommend to buy. I ask because after looking there seem to be endless choices and so many look sketchy.
Thank you in advance
Reactions: TheRealPorkchop
Amp is the best.
But I use RF Industries and Laird connectors.
I don't think amphenol makes a solder and crimp connector but I may be wrong. I'm specifically speaking of solder crimp in this case as in strait solder amphenol holds the bar above the rest in any rf connector period.
Reactions: TIN_CAN
I've used these (rfc) View attachment 41482 for a few years now and they work really well. Silver and Teflon with good quality build. Well I ran coax in the truck last week and used the last 2 and the seller is all out of them.
I have used those and the dx engineering brand. I feel like the dex connector is better quality but have no issues with either.
I might have done this one wrong. :D
Thanks for your input, I saw those at dx engineering and they do look quality as pretty sure they are coming from there.
That's one way to do it (the picture)
Just checked your link and those look like a good candidate also.
I appreciate you fellas input, that's why I ask here so to hopefully spare myself from buying junk.
Reactions: Tokin and Riverman
Reactions: Eldorado828
https://qsradio.com/shop-now.html#!/Crimp-On-Coax-Connectors/c/11543083
